Fusion Manufacture
Feed/revolution and feed/min are missing in drill operations
6 REPLIES 6
tisler
224 Views, 6 Replies
Woke up to a whole new level of bug.
I want to set feed/revolution, in drill operation, put there is no setting for it.
Feed/min is also missing.
 Anyone ???
6 REPLIES 6
seth.madore
in reply to: tisler
You mean the "Plunge Feed Per Revolution"?
The drill dialog was changed recently, and it's certainly generated its share of confusion among the community. We are working at improving this dialog!
Seth Madore
tisler
in reply to: tisler
Plunge/rev is ment to be drill feed in mm/rev ?
seth.madore
in reply to: tisler
Yes
Seth Madore
tisler
in reply to: tisler
Well, that was confusing. I spend al lot of time figuring that out.
I am not native english speaker and that plunge did not make any sense.
thanks
seth.madore
in reply to: tisler
thanks
Oh, that's interesting, good to know. Do you use Fusion in English, or is it "localized" (translated into your native tongue)?
Seth Madore
tisler
in reply to: tisler
Fusion does not support Slovenian, so I am using it in English.
No problem here, I just iterpreted term plunge as a fast move (GO) to certan position, then I assumed drill feedrate is missing…
