Fusion Manufacture
Fanuc Probing Help
7 REPLIES 7
Message 1 of 8
amessina
202 Views, 7 Replies
Fanuc Probing Help
Hey guys hoping someone can help me...using the "Fanuc Inspection.cps" from autodesk, if I do three probing cycles in a row it tries to spin the probe on and off for every cycle.  Is there anyway to do this automatically instead of by hand?  See sample code below.  Any help would be greatly appreciated.
7 REPLIES 7
Message 2 of 8
amessina
in reply to: amessina
New to forum, not sure how to edit.
I would like to turn the probe on with the first WCS toolpath and off with the last WCS? Is there anyway to do this in the post?
Message 3 of 8
BrandonTBFBF
Does this accomplish what you're looking for?
EDIT - File removed
Message 4 of 8
amessina
in reply to: BrandonTBFBF
Thanks a bunch, this is super close to what I was asking...only issue is that it doesn't spin the probe off.
Message 5 of 8
BrandonTBFBF
Can you attach your F3D file
Message 6 of 8
amessina
Here you go.
Message 7 of 8
BrandonTBFBF
Try this
Message 8 of 8
amessina
That worked perfect...for anywell else in the same boat...Brandon is the Man!
Thanks a bunch.
AJ
