Fusion Manufacture
Fanuc post processor edit to output G53 X0. Y0. after the G53 G00 Z0 line
6 REPLIES 6
Nathan_at_Doughty
400 Views, 6 Replies
I was hoping i could get some help/be pointed in the right direction with something I am trying to add into  my Fanuc post Processor. I have basic post processor editing capabilities at best. I am trying to get my Fanuc post processor to output G53 X0. Y0. after the G53 G00 Z0 line (for a safe tool change position) any suggestions as to the best route to go would be greatly appreciated.
Thanks 👍
6 REPLIES 6
Hi @Nathan_at_Doughty ,
Add following if condition in function onSection.
    // retract to safe plane
    writeRetract(Z); // retract
    if ((insertToolCall && !isFirstSection())) {
      writeRetract(X, Y);
Save the post modification and test the code.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
mirmetY2P6N
in reply to: KrupalVala
Hello
Could You help me with that ? I have no idea where should I change my postprocessor.
Thx in advance
Martin
KrupalVala
in reply to: mirmetY2P6N
Hi @mirmetY2P6N ,
Please add the codes at following highlited area.
Krupal Vala
I have posted the code into my post processor, I believe I have done it correctly, but it is posting the retract X and Y movements via a G28 code rather than a G53? I have attached a picture. maybe you can see where I have gone wrong?
You need to set your Retract option to G53 (default is G28), this is the Post Properties at posting time
Seth Madore
Hi Seth,
That worked out great. thanks for your help on the issue
