Fanuc post - permitted characters
Does anyone know what should be the syntax to make inch symbol character permitted?
I have added + and / but I assume if I want to add " symbol it has to be written differently.
var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-+/";
Marek
HughesTooling
After a quick Google it looks like you add a backward slash in front of the quote, so \"
I haven't tested so might not work.
Mark Hughes
Owner, Hughes Tooling
I would call it slash /.  We use it at tool description like 3/8" dia end mill ..
and this works well. So far the only problem case me " character.
Marek
HughesTooling
OK all you need to do is use a single quote around the string then you can add a double quote inside like this.
var permittedCommentChars = ' ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-+/"';
Mark
Mark Hughes
Works,
Thanks a lot
Marek
