Fusion Manufacture
FAnuc inspection post
7 REPLIES 7
Message 1 of 8
paulo2Z36L
311 Views, 7 Replies
I need info about this error in the inspection fanuc post. somehow a cam parameter (i assume) is not read correctly and it outputs code that the machine won't read.
(GEOMETRY ONLY)
N65 #8=#[2000 + #4111]
N70 #1=[[#500 + #501]/2]
N75 #9=PRM[6014,4]  <---------- this liene causes me trouble....don<t know why is wont get a value
N80 IF [#9 EQ 0] GOTO90
N85 #8 = 0
thank you
7 REPLIES 7
Message 2 of 8
Hi @paulo2Z36L
That's all about the tool length, first thing I notice is you have the post property "Tool offset Type" or something like that. Set to Geometry only. Possibly your machine has 2 columns on the tool offset page. If you have 2 columns, one for geometry and one for wear then please set that post property to "Geometry and Wear"
Give that a go and let me know how you get on.
Richard Stubley
Manager - Manufacturing Specialist Team
Message 3 of 8
paulo2Z36L
in reply to: paulo2Z36L
Juste tried it....
I keep geting the same error.
(GEOMETRY AND WEAR)
N65 #8=#[2000 + #4111] + #[2200 + #4111]
N75 #9=PRM[6014,4]
N85 #8 = 0
Below is a is a copy paste from of post...see section in bold.
 isDPRNTopen = true;
  if (inspectionVariables.toolLengthParameterCheck) {
    forceSequenceNumbers(true);
    writeBlock(inspectionVariables.macroVariable1 + "=PRM[6014,4]");
    writeBlock("IF [" + inspectionVariables.macroVariable1 + " EQ 0] GOTO" + skipNLines(2));
    writeBlock(inspectionVariables.activeToolLength + " = 0");
    writeBlock(" ");
    forceSequenceNumbers(false);
function inspectionProcessSectionEnd() {
  // close inspection results file if the NC has inspection toolpaths
  if (inspectionVariables.hasInspectionSections) {
    if (getProperty("commissioningMode") && inspectionVariables.printParameterCheck) {
      writeBlock(inspectionVariables.macroVariable1 + "=PRM[6019,3]"); <----- tihs one here seem to be read...somehow
basically it's checking for a tool lenght offset at 0. Maybe i could use a #2200 parameter...
This is for a M80 control, fanuc compatible.
Message 4 of 8
Just tried it....
(GEOMETRY AND WEAR)
N75 #9=PRM[6014,4]
N85 #8 = 0
isDPRNTopen = true;
writeBlock(" ");
Message 5 of 8
Hi @paulo2Z36L
It just checks for wether the tool length is already accounted by the machine or not if we call the #5063 variable.
you can disable this check in the post as most of the machines will include the tool length compensation value when we call #5063.
Edit the post and find for this line in the post
toolLengthParameterCheck       : true,
and set it to false
toolLengthParameterCheck       : false,
this should not output the PRM section of codes in the nc
Boopathi Sivakumar
Senior Technology Consultant
Message 6 of 8
Hi @paulo2Z36L out of interest what is the error you are getting on the machine?
Richard Stubley
Message 7 of 8
Sounds good. I will give it a try.
It's only when i use inspection surface on fusion, all other probing strategies work just fine.
thank you
Message 8 of 8
Machine will give we '' unpaired brackets error''.
i tried to see what this parameter was for ans pulled out all the documententation....and it seems that it's nowhere used....
This occrurs only when I use the Inspection surface option, other options seem to work just fine (bore, web, etc).
I will disable this conftions, as per susgested above. Or I'll just ut in my machine active length parameters. It only for the DPRNT block, from what I see. My built in macros fro probing work just fine using the the active tool lenght.
I'll get back to you guys, as it might become handy for someelse using Mitsubishi M80/M70 controls or Fanuc 16-18-20. Mine is
Thank you
