Fusion Manufacture
Fanuc Inspection Post Processor Probing Errors
2 REPLIES 2
Madsenalex25
199 Views, 2 Replies
HI there,
I am using the Fanuc Inspection post with a RoboDrill, Post works fine for 5 axis work and post also outputs the correct code. Unfortunately it does not simulate the correct moves when using inspect surface (see attached) the Z axis never drops below the surface of the part. I do not have this issue on my Heidenhain Post. Also the machine simulation does not work with Probing WCS (see attached error) it only seems to work with Inspect Surface. Probe Geometry and Probe WCS do not allow machines sim to work.
Attached in a comment are the machine and post file.
2 REPLIES 2
Madsenalex25
in reply to: Madsenalex25
Here are the Machine and Post
Madsenalex25
Machine
