Fusion Manufacture
Fanuc driling cycles F and Q parameter eror
6 REPLIES 6
CAMtech_Software
345 Views, 6 Replies
in drilling cycles fanuc post is making mmpr/mmpm error as progress. Live tool selection is disabled in tool definition. The cycles Q value does not come in thousands.
O1001
N10 G98 G18
N11 G21
N12 G50 S6000
N13 G28 U0.
N14 G28 W0.
(DELGI1 2)
N15 T0606
N16 G98 G18
N17 G54
N18 M8
N19 G97 S909 M3
N20 G0 X0. Z18.
N21 G0 Z8.
N22 G83 X0. Z-35. R5. Q5. F73.  ( G83 X0. Z-35. R5. Q5000. F0.08)
N23 G80
N24 Z18.
N25 M9
N26 G28 U0.
N27 G28 W0.
N28 M30
6 REPLIES 6
Fanuc 2x turning post
CNC_Lee
in reply to: CAMtech_Software
@CAMtech_Software
This post will need to be edited and configured properly to achieve the correct output required. If you are not comfortable making these edits, there are professionals who can edit the post to fit your needs!
If my post answers your question, please use Accept as Solution.
CNC Lee
Fusion 360 CAM Post Processor Expert
https://linktr.ee/cnclee
CAMtech_Software
in reply to: CNC_Lee
I can understand you but this is not customization. Is it a standard feature for Fanuc turning and a problem in F360?
Arun.rs
HI @CAMtech_Software
This support requires the allowFeedPerRevolutionDrilling variable to be set to true so that the post engine knows that the post processor will accept FPR feedrates plus other logic to output the correct feedrate mode code and the proper feedrate number.
minimumChordLength = spatial(0.25, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = false;
allowedCircularPlanes = 1 << PLANE_ZX; // allow ZX plane only
allowFeedPerRevolutionDrilling = true; >>>>>>>>>>>>>>> Add this here
Regards
Arun.RS
Technical Consultant - Post Processor
Arun.rs
in reply to: Arun.rs
The Q value to come in thousands, enable the second 'var peckFormat' in post,
//var peckFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var peckFormat = createFormat({decimals:0, forceDecimal:false, trim:false, width:4, zeropad:true, scale:(unit == MM ? 1000 : 10000)});
Regards
Arun.RS
CAMtech_Software
Going too far as I couldn't see what you wrote. Thanks for the solution. All issues have been resolved
O1001
N10 G98 G18
N11 G21
N12 G50 S6000
N13 G28 U0.
N14 G28 W0.
(DELGI1 2)
N15 T0606
N16 G99 G18
N17 G54
N18 M8
N19 G97 S909 M3
N20 G0 X0. Z18.
N21 G0 Z8.
N22 G83 X0. Z-35. R5. Q5000 F0.08
N23 G80
N24 Z18.
N25 M9
N26 G28 U0.
N27 G28 W0.
N28 M30
