- Mute
- Permalink
- Report
I have been struggling over the last few days to get fusion to output g code. I'm not sure what has changed but none of my parts will post even though I have posted them and cut them in the past. The most current part that I am working on I receive the following message when I attempt tp post the code. Strangely there is code when I open the TAP file that is saved by fusion but I don't want to run it with the message that I am given.
Information: Configuration: Mach3Mill
Information: Vendor: Artsoft
Information: Posting intermediate data to 'E:\cnc projects\raven 1.tap'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Sunday, November 29, 2020 12:24:05 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5720.0
Configuration path: C:\Users\Nick\AppData\Local\Autodesk\webdeploy\production\ca426f89300c9832c554fb1598dc1364864ea03e\Applications\CAM360\Data\Posts\mach3mill.cps
Include paths: C:\Users\Nick\AppData\Local\Autodesk\webdeploy\production\ca426f89300c9832c554fb1598dc1364864ea03e\Applications\CAM360\Data\Posts
Configuration modification date: Wednesday, October 7, 2020 2:07:07 PM
Output path: E:\cnc projects\raven 1.tap
Checksum of intermediate NC data: 96fc6170a6fc4c94d2a827c6ae869d6e
Checksum of configuration: d187e848dceac72ac216f7a2738be881
Vendor url: http://www.machsupport.com
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.9313
Error: Failed to write output stream.
Error: Failed to execute configuration.
Stop time: Sunday, November 29, 2020 12:24:07 AM
Error: Failed to close output stream.
Error in operation: 'Adaptive4'
Failed while processing onLinear() for record 20944.
Post processing failed.
Fusion
