- Mute
- Permalink
- Report
I have been using F360 now for a couple of years for 3d printing and going good. I recently got my Snapmaker 2.0 which can do milling. Well after jumping many hoops to get F360 to post in a .CNC file I finally got it to work meaning got the Snapmaker 2.0 to open and run a file from F360. But now here is my issue. I've watched many different videos on facing but I still must be missing something obvious. When I post and open the gcode file to see what F360 output the Z is never going -Z. I'm trying to remove about 4mm of stock from the top of the stock to get to the top of my model. Yet nothing I am changing seems to make a difference. If I setup my origin on my mill and the tip of the cutter is at Z 0.0 then if it is going to cut in to the piece it has to go -Z. The gcode that F360 outputs is going from Z 3.0 to Z 0 when it should be Z 0 to Z -3.0. Any clues as to what I am missing?? Everything in F360 looks right when I do the simulation it looks correct.
