Fusion Manufacture
Facing operation, chip thining doesn't work
8 REPLIES 8
Message 1 of 9
ole.alex
245 Views, 8 Replies
I'm trying to use chip thinning/rolling into the cut when doing a facing operation, but enabling chip thinning does not change the toolpath.
I've tried several different tools, but not difference, i guess it must be a bug?
Surface finish is poor on the start of the cut which is the reason i would like to test chip thinning.
8 REPLIES 8
Message 2 of 9
seth.madore
in reply to: ole.alex
Nope, it doesn't look like it works, does it 🤔
I've opened up CAM-44050 to investigate this, thanks for letting us know!
Seth Madore
Message 3 of 9
csl1016
Message 4 of 9
seth.madore
@csl1016
Ah, Pass Extension prevents the use of Chip Thinning. Good to know, thanks
Seth Madore
Message 5 of 9
Don.Cyr
@seth.madore Search through the CAB, I'm pretty sure I remember seeing some discussion about this a while ago..
Please click "Accept Solution" if I helped with your question or issue.
Message 6 of 9
seth.madore
in reply to: Don.Cyr
Yeah, I recall seeing that thread, but didn't follow it too close. I took a tally of how many channels I'm involved in; 118 separate channels. It becomes rather difficult to keep tabs of what conversation came from where (and when)
Seth Madore
Message 7 of 9
ole.alex
So chip thining is working, but can't be combined with one of the default settings, i'd say that's a good reason to create a warning message when combining chip thinning and pass extension since pass extension is enabled by default.
Message 8 of 9
seth.madore
Yep, that's what the ticket I created is about:
"Chip Thinning" does not work when a Pass Extension is defined. Possible improvement to warning or tooltip?"
Seth Madore
Message 9 of 9
oleg.tikhomirov
It looks like algorithm checks stock. I see that "chip thinning" works when "stock offset" is used instead of "pass extension". Cutting paths are not exactly the same but similar.
Oleg Tikhomirov
Software Engineer
