Face toolpath from sketch - wont generate.
changedsoul
changedsoul
I have no clue what I am doing wrong. I created a simple sketch, basically a dowel pin.
When I try to create a face tool path, it never generates.
I have Stock set, the stock is in front of the actual profile, so there is stock to be removed.
I don't see a way to actually select any geometry for facing.
akash.kamoolkar
@changedsoul
Is this a turning job? Can you attach your file?
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
changedsoul
Yes this is a lathe job.
I am sorry, but I do not know how to attach the file. Can you lend a hand?
Edit...I exported as .fd3 and attached this...is this what your looking for?
s.noke71
Can you revolve the sketch a make a solid dowel, its easier to work with solids in turning
akash.kamoolkar
Like @s.noke71  said, I revolved the sketch to create a model and then I got a toolpath.
Akash Kamoolkar
Akash Kamoolkar
changedsoul
So would this be a bug then for turning, facing using only a sketch?
