Fusion Manufacture
Face Milling Operation Lead in and Lead out Reversed
5 REPLIES 5
dmayRAGCW
443 Views, 5 Replies
I have been trying to resolve an issue that I assumed was my post processor for quite some time. However, today I actually posted the Cutter Location file found Fusion is sending a CW "lead in" as CCW to the post processor. Also a CCW "lead out" I have on the same part is being sent as CW to the post processor. The Toolpath display inside Fusion shows the same error.
Attached is an example F3D file. Below is the Cutter Location Data post from the same file.
<?xml version='1.0' encoding='utf-8' standalone='yes'?>
<nc xmlns='http://www.hsmworks.com/xml/2008/nc' version='1.0'>
<!-- http://cam.autodesk.com -->
<parameter name='product-id' value='fusion360' type='string'/>
<parameter name='generated-by' value='Fusion 360 CAM 2.0.8624' type='string'/>
<parameter name='generated-at' value='Tuesday, July 21, 2020 1:42:51 PM' type='string'/>
<parameter name='hostname' value='WCC-1608-DMAY.WALBRONA.WALBROEM.LLC' type='string'/>
<parameter name='username' value='dmay' type='string'/>
<parameter name='document-path' value='Untitled' type='string'/>
<parameter name='document-id' value='984b1eff-d9ae-4fbd-94c1-9ae034821e01' type='string'/>
<parameter name='model-version' value='165117d7-f095-47fb-b92c-0b3f2750f62b' type='string'/>
<parameter name='leads-supported' value='1' type='integer'/>
<parameter name='job-description' value='Setup1' type='string'/>
<parameter name='stock-type' value='box' type='string'/>
<parameter name='stock' value='((-31.496, -28.956, -51.816), (31.496, 28.956, 0))' type='string'/>
<parameter name='stock-lower-x' value='-1.24' type='float'/>
<parameter name='stock-lower-y' value='-1.14' type='float'/>
<parameter name='stock-lower-z' value='-2.04' type='float'/>
<parameter name='stock-upper-x' value='1.24' type='float'/>
<parameter name='stock-upper-y' value='1.14' type='float'/>
<parameter name='stock-upper-z' value='0' type='integer'/>
<parameter name='part-lower-x' value='-1.2' type='float'/>
<parameter name='part-lower-y' value='-1.1' type='float'/>
<parameter name='part-lower-z' value='-2.04' type='float'/>
<parameter name='part-upper-x' value='1.2' type='float'/>
<parameter name='part-upper-y' value='1.1' type='float'/>
<parameter name='part-upper-z' value='-0.04' type='float'/>
<parameter name='notes' value='' type='string'/>
<parameter name='operation-strategy' value='face' type='string'/>
<parameter name='operation-comment' value='Face1' type='string'/>
<parameter name='autodeskcam:operation-id' value='3' type='integer'/>
<parameter name='autodeskcam:path' value='Setups\Setup1\Face1' type='string'/>
<parameter name='operation:is2DStrategy' value='1' type='integer'/>
<parameter name='operation:is3DStrategy' value='0' type='integer'/>
<parameter name='operation:isRoughingStrategy' value='0' type='integer'/>
<parameter name='operation:isFinishingStrategy' value='1' type='integer'/>
<parameter name='operation:isMillingStrategy' value='1' type='integer'/>
<parameter name='operation:isTurningStrategy' value='0' type='integer'/>
<parameter name='operation:isJetStrategy' value='0' type='integer'/>
<parameter name='operation:isAdditiveStrategy' value='0' type='integer'/>
<parameter name='operation:isProbingStrategy' value='0' type='integer'/>
<parameter name='operation:isInspectionStrategy' value='0' type='integer'/>
<parameter name='operation:isDrillingStrategy' value='0' type='integer'/>
<parameter name='operation:isHoleMillingStrategy' value='0' type='integer'/>
<parameter name='operation:isThreadStrategy' value='0' type='integer'/>
<parameter name='operation:isSamplingStrategy' value='0' type='integer'/>
<parameter name='operation:isRotaryStrategy' value='0' type='integer'/>
<parameter name='operation:isSecondarySpindleStrategy' value='0' type='integer'/>
<parameter name='operation:isSurfaceStrategy' value='0' type='integer'/>
<parameter name='operation:isCheckSurfaceStrategy' value='0' type='integer'/>
<parameter name='operation:isMultiAxisStrategy' value='0' type='integer'/>
<parameter name='operation:advancedMode' value='0' type='integer'/>
<parameter name='operation:betaMode' value='0' type='integer'/>
<parameter name='operation:alphaMode' value='0' type='integer'/>
<parameter name='operation:isXpress' value='0' type='integer'/>
<parameter name='operation:licenseMultiaxis' value='1' type='integer'/>
<parameter name='operation:license3D' value='1' type='integer'/>
<parameter name='operation:metric' value='0' type='integer'/>
<parameter name='operation:isAssemblyDocument' value='1' type='integer'/>
<parameter name='operation:context' value='operation' type='string'/>
<parameter name='operation:strategy' value='face' type='string'/>
<parameter name='operation:operation_description' value='Face' type='string'/>
<parameter name='operation:tool_type' value='flat end mill' type='string'/>
<parameter name='operation:undercut' value='0' type='integer'/>
<parameter name='operation:tool_isTurning' value='0' type='integer'/>
<parameter name='operation:tool_isMill' value='1' type='integer'/>
<parameter name='operation:tool_isDrill' value='0' type='integer'/>
<parameter name='operation:tool_taperedType' value='tapered_bull_nose' type='string'/>
<parameter name='operation:tool_unit' value='inches' type='string'/>
<parameter name='operation:tool_number' value='1' type='integer'/>
<parameter name='operation:tool_diameterOffset' value='1' type='integer'/>
<parameter name='operation:tool_lengthOffset' value='1' type='integer'/>
<parameter name='operation:tool_compensationOffset' value='1' type='integer'/>
<parameter name='operation:tool_turret' value='0' type='integer'/>
<parameter name='operation:tool_manualToolChange' value='0' type='integer'/>
<parameter name='operation:tool_breakControl' value='0' type='integer'/>
<parameter name='operation:tool_live' value='1' type='integer'/>
<parameter name='operation:tool_coolant' value='flood' type='string'/>
<parameter name='operation:tool_material' value='carbide' type='string'/>
<parameter name='operation:tool_description' value='' type='string'/>
<parameter name='operation:tool_comment' value='' type='string'/>
<parameter name='operation:tool_vendor' value='' type='string'/>
<parameter name='operation:tool_productId' value='' type='string'/>
<parameter name='operation:tool_diameter' value='0.4985' type='float'/>
<parameter name='operation:tool_tipDiameter' value='0.4985' type='float'/>
<parameter name='operation:tool_tipOffset' value='0' type='integer'/>
<parameter name='operation:tool_cornerRadius' value='0' type='integer'/>
<parameter name='operation:tool_taperAngle' value='0' type='integer'/>
<parameter name='operation:tool_tipAngle' value='0' type='integer'/>
<parameter name='operation:tool_threadProfileAngle' value='0' type='integer'/>
<parameter name='operation:tool_tipLength' value='0' type='integer'/>
<parameter name='operation:tool_fluteLength' value='1' type='float'/>
<parameter name='operation:tool_shoulderLength' value='1.75' type='float'/>
<parameter name='operation:tool_bodyLength' value='1.75' type='float'/>
<parameter name='operation:tool_overallLength' value='3' type='float'/>
<parameter name='operation:tool_shaftDiameter' value='0.5' type='float'/>
<parameter name='operation:tool_segmentHeight' value='0.25' type='float'/>
<parameter name='operation:tool_segmentDiameterLower' value='1' type='float'/>
<parameter name='operation:tool_segmentDiameterUpper' value='1' type='float'/>
<parameter name='operation:tool_shaftSegmentHeight' value='0.03937' type='float'/>
<parameter name='operation:tool_shaftSegmentDiameterLower' value='0.4985' type='float'/>
<parameter name='operation:tool_shaftSegmentDiameterUpper' value='0.5' type='float'/>
<parameter name='operation:tool_threadPitch' value='0' type='integer'/>
<parameter name='operation:tool_numberOfTeeth' value='0' type='integer'/>
<parameter name='operation:tool_numberOfFlutes' value='4' type='integer'/>
<parameter name='operation:holder_attached' value='0' type='integer'/>
<parameter name='operation:holder_description' value='Maritool CAT40-ER32-2.35' type='string'/>
<parameter name='operation:holder_comment' value='' type='string'/>
<parameter name='operation:holder_vendor' value='Maritool' type='string'/>
<parameter name='operation:holder_productId' value='CAT40-ER32-2.35' type='string'/>
<parameter name='operation:holder_productLink' value='' type='string'/>
<parameter name='operation:holder_libraryName' value='' type='string'/>
<parameter name='operation:tool_productLink' value='' type='string'/>
<parameter name='operation:tool_spindleSpeed' value='2700' type='integer'/>
<parameter name='operation:tool_stockDiameter' value='0.4985' type='float'/>
<parameter name='operation:tool_surfaceSpeed' value='4228.426632' type='float'/>
<parameter name='operation:tool_rampSpindleSpeed' value='2700' type='integer'/>
<parameter name='operation:tool_feedCutting' value='100' type='integer'/>
<parameter name='operation:tool_feedPerTooth' value='0.009259' type='float'/>
<parameter name='operation:tool_feedProbeLink' value='120' type='integer'/>
<parameter name='operation:tool_feedEntry' value='75' type='integer'/>
<parameter name='operation:tool_feedExit' value='75' type='integer'/>
<parameter name='operation:tool_feedProbeMeasure' value='12' type='float'/>
<parameter name='operation:tool_feedRamp' value='55' type='integer'/>
<parameter name='operation:tool_feedPlunge' value='55' type='integer'/>
<parameter name='operation:tool_feedPerRevolution' value='0.02037' type='float'/>
<parameter name='operation:tool_feedRetract' value='55' type='integer'/>
<parameter name='operation:tool_clockwise' value='1' type='integer'/>
<parameter name='operation:featureOperationId' value='none' type='string'/>
<parameter name='operation:surfaceZHigh' value='-0.04' type='float'/>
<parameter name='operation:surfaceZLow' value='-2.04' type='float'/>
<parameter name='operation:surfaceXLow' value='-1.2' type='float'/>
<parameter name='operation:surfaceXHigh' value='1.2' type='float'/>
<parameter name='operation:surfaceYLow' value='-1.1' type='float'/>
<parameter name='operation:surfaceYHigh' value='1.1' type='float'/>
<parameter name='operation:stockZHigh' value='0' type='integer'/>
<parameter name='operation:stockZLow' value='-2.04' type='float'/>
<parameter name='operation:stockXLow' value='-1.24' type='float'/>
<parameter name='operation:stockXHigh' value='1.24' type='float'/>
<parameter name='operation:stockYLow' value='-1.14' type='float'/>
<parameter name='operation:stockYHigh' value='1.14' type='float'/>
<parameter name='operation:view_orientation_mode' value='useWCS' type='string'/>
<parameter name='operation:view_orientation_flipZ' value='0' type='integer'/>
<parameter name='operation:view_orientation_flipX' value='0' type='integer'/>
<parameter name='operation:view_orientation_flipY' value='0' type='integer'/>
<parameter name='operation:view_origin_mode' value='jobOrigin' type='string'/>
<parameter name='operation:view_origin_boxPoint' value='top center' type='string'/>
<parameter name='operation:view_turn_from_setup' value='0' type='integer'/>
<parameter name='operation:view_tilt_from_setup' value='0' type='integer'/>
<parameter name='operation:view_turn_from_recipe' value='0' type='integer'/>
<parameter name='operation:view_tilt_from_recipe' value='0' type='integer'/>
<parameter name='operation:clearanceHeight_mode' value='from retract height' type='string'/>
<parameter name='operation:clearanceHeight_offset' value='0.4' type='float'/>
<parameter name='operation:clearanceHeight_value' value='0.6' type='float'/>
<parameter name='operation:clearanceHeight_absolute' value='1' type='integer'/>
<parameter name='operation:retractHeight_mode' value='from stock top' type='string'/>
<parameter name='operation:retractHeight_offset' value='0.2' type='float'/>
<parameter name='operation:retractHeight_value' value='0.2' type='float'/>
<parameter name='operation:retractHeight_absolute' value='1' type='integer'/>
<parameter name='operation:feedHeight_mode' value='from top' type='string'/>
<parameter name='operation:feedHeight_offset' value='0.2' type='float'/>
<parameter name='operation:feedHeight_value' value='0.2' type='float'/>
<parameter name='operation:useZFeed' value='1' type='integer'/>
<parameter name='operation:feedHeight_absolute' value='1' type='integer'/>
<parameter name='operation:topHeight_mode' value='from stock top' type='string'/>
<parameter name='operation:topHeight_offset' value='0' type='integer'/>
<parameter name='operation:topHeight_value' value='0' type='integer'/>
<parameter name='operation:topHeight_absolute' value='1' type='integer'/>
<parameter name='operation:bottomHeight_mode' value='from surface top' type='string'/>
<parameter name='operation:bottomHeight_offset' value='0' type='integer'/>
<parameter name='operation:bottomHeight_value' value='-0.04' type='float'/>
<parameter name='operation:bottomHeight_absolute' value='1' type='integer'/>
<parameter name='operation:tolerance' value='0.0004' type='float'/>
<parameter name='operation:contourTolerance' value='0.0002' type='float'/>
<parameter name='operation:calculationTolerance' value='0.0004' type='float'/>
<parameter name='operation:thinningTolerance' value='0.000004' type='float'/>
<parameter name='operation:chainingTolerance' value='0.0004' type='float'/>
<parameter name='operation:gougingTolerance' value='0.0004' type='float'/>
<parameter name='operation:passAngle' value='0' type='integer'/>
<parameter name='operation:passExtension' value='0' type='integer'/>
<parameter name='operation:stockOffset' value='0' type='integer'/>
<parameter name='operation:stepover' value='0.473575' type='float'/>
<parameter name='operation:direction' value='both ways' type='string'/>
<parameter name='operation:fromOtherSide' value='0' type='integer'/>
<parameter name='operation:useChipThinning' value='0' type='integer'/>
<parameter name='operation:rollInRadius' value='0.24925' type='float'/>
<parameter name='operation:extendEndPasses' value='0' type='integer'/>
<parameter name='operation:maximumStepdown' value='0' type='integer'/>
<parameter name='operation:bothSides' value='0' type='integer'/>
<parameter name='operation:doFinishingStep' value='0' type='integer'/>
<parameter name='operation:finishFeedrate' value='100' type='integer'/>
<parameter name='operation:finishingStepdown' value='-0.03937' type='float'/>
<parameter name='operation:useEvenStepdowns' value='0' type='integer'/>
<parameter name='operation:verticalStockToLeave' value='0' type='integer'/>
<parameter name='operation:highFeedrateMode' value='disabled' type='string'/>
<parameter name='operation:highFeedrate' value='100' type='integer'/>
<parameter name='operation:allowRapidRetract' value='1' type='integer'/>
<parameter name='operation:keepToolDown' value='1' type='integer'/>
<parameter name='operation:stayDownDistance' value='2.4925' type='float'/>
<parameter name='operation:extendBeforeRetract' value='0' type='integer'/>
<parameter name='operation:doLeadIn' value='1' type='integer'/>
<parameter name='operation:entry_verticalRadius' value='0.04985' type='float'/>
<parameter name='operation:leadInVerticalRadius' value='0.04985' type='float'/>
<parameter name='operation:doLeadOut' value='1' type='integer'/>
<parameter name='operation:exit_sameAsEntry' value='1' type='integer'/>
<parameter name='operation:exit_verticalRadius' value='0.04985' type='float'/>
<parameter name='operation:leadOutVerticalRadius' value='0.04985' type='float'/>
<parameter name='operation:transitionType' value='curve' type='string'/>
<parameter name='operation:use_tool_stepdown' value='0' type='integer'/>
<parameter name='operation:tool_stepdown' value='0.04' type='float'/>
<parameter name='operation:tool_finishingStepdown' value='0.008' type='float'/>
<parameter name='operation:use_tool_stepover' value='0' type='integer'/>
<parameter name='operation:tool_stepover' value='0.24925' type='float'/>
<parameter name='operation:tool_finishingStepover' value='0.04985' type='float'/>
<parameter name='operation:tool_rampType' value='helix' type='string'/>
<parameter name='operation:tool_rampAngle' value='2' type='integer'/>
<parameter name='movement:lead_in' value='1905' type='integer'/>
<parameter name='movement:cutting' value='2540' type='integer'/>
<parameter name='movement:lead_out' value='1905' type='integer'/>
<parameter name='movement:transition' value='2540' type='integer'/>
<parameter name='movement:direct' value='2540' type='integer'/>
<parameter name='movement:helix_ramp' value='1397' type='integer'/>
<parameter name='movement:profile_ramp' value='1397' type='integer'/>
<parameter name='movement:zigzag_ramp' value='1397' type='integer'/>
<parameter name='movement:ramp' value='1397' type='integer'/>
<parameter name='movement:plunge' value='1397' type='integer'/>
<parameter name='movement:predrill' value='2540' type='integer'/>
<parameter name='movement:extended' value='2540' type='integer'/>
<parameter name='movement:reduced' value='2540' type='integer'/>
<parameter name='movement:finish_cutting' value='2540' type='integer'/>
<context unit='inches' origin='0 0 0' plane='1 0 0 0 1 0 0 0 1' work-offset='0'/>
<tool type='unspecified' number='1' diameter='0.4985' corner-radius='0' taper-angle='0' flute-length='1' shoulder-length='1.75' body-length='1.75' shaft-diameter='0.5' thread-pitch='0' diameter-offset='1' length-offset='1' spindle-rpm='2700' coolant='flood'>
<holder>
<section diameter='1.5' length='0'/>
<section diameter='1.97' length='0.148'/>
<section diameter='1.97' length='0.836'/>
<section diameter='1.57' length='0'/>
<section diameter='1.57' length='0.176'/>
<section diameter='1.75' length='0.09'/>
<section diameter='1.75' length='0.425'/>
<section diameter='1.85' length='0.05'/>
<section diameter='2.442' length='0'/>
<section diameter='2.502' length='0.03'/>
<section diameter='2.502' length='0.145'/>
<section diameter='2.215' length='0.079'/>
<section diameter='2.215' length='0.118'/>
<section diameter='2.502' length='0.079'/>
<section diameter='2.502' length='0.143'/>
<section diameter='2.442' length='0.03'/>
<section diameter='1.75' length='0'/>
<section diameter='1.75' length='0.125'/>
</holder>
</tool>
<section>
<rapid to='1.564025 -0.927916 0.6'/>
<rapid to='1.564025 -0.927916 0.2'/>
<linear to='1.564025 -0.927916 0.00985' feed='75.000'/>
<arc-ccw to='1.514175 -0.927916 -0.04' center='1.514175 -0.927916 0.00985' normal='0 1 0'/>
<linear to='1.24 -0.927916 -0.04'/>
<linear to='-1.24 -0.927916 -0.04' feed='100.000'/>
<arc-cw to='-1.24 -0.471318 -0.04' center='-1.24 -0.699617 -0.04'/>
<linear to='1.24 -0.471318 -0.04'/>
<arc-ccw to='1.24 -0.01472 -0.04' center='1.24 -0.243019 -0.04'/>
<linear to='-1.24 -0.01472 -0.04'/>
<arc-cw to='-1.24 0.441879 -0.04' center='-1.24 0.213579 -0.04'/>
<linear to='1.24 0.441879 -0.04'/>
<arc-ccw to='1.24 0.898477 -0.04' center='1.24 0.670178 -0.04'/>
<linear to='-1.24 0.898477 -0.04'/>
<arc-ccw to='-1.28985 0.898477 0.00985' center='-1.24 0.898477 0.00985' normal='0 1 0' feed='75.000'/>
<rapid to='-1.28985 0.898477 0.6'/>
</section>
</nc>
Labels (1)
5 REPLIES 5
DarthBane55
in reply to: dmayRAGCW
This arc is in G18 (XZ) plane.  Refer to pictures below for G02-G03 on that plane, your code is fine.  To double check, I posted your file with my post, which I use daily with G18 arcs too and it was always fine the way the code outputs with your file.  I also backplotted it with a g-code editor and it interprets it correctly.
dmayRAGCW
in reply to: DarthBane55
You are correct about the G18 plane... I guess I didn't even consider that. So my next conclusion is that the G18 plane is reversed on a Hurco controller. If I back plot my file to run on a Fanuc it displays the leads correctly. However, if I change it to Heidenhain (which reflects my Hurco). It reverses those radii.
dmayRAGCW
I will have to resolve this in my post processor. Below is a snip from machine manual. Thank you for your help and leading me to look this direction.
DarthBane55
I see, I only have Fanucs!  Well, at least it got you looking in the right direction!
chris.rouxel88
getParameter("operation:tool_feedProbeMeasure")
