Fusion Manufacture
F360 hangs on clicking Setup Machine
1 REPLY 1
DaveJGRO
69 Views, 1 Reply
I hadn't used F360 in a while and started it today, did the latest update, and rebooted the program.
I built a simple model, and then went to Manufacture, then Setup.  The model only has an extruded cube-ish item -- nothing complex.  I am able to click Model/Model and select the Body.  When I click on Machine/Machine(Select...), it hangs.  I had to do ctrl-alt-del and kill the process.
I had pre-defined machine settings for my CNC and I'm hoping those aren't lost now.
Any ideas on how I can diagnose this?
1 REPLY 1
DaveJGRO
in reply to: DaveJGRO
Ha!
Bonehead move on my part.
I recently switched to dual monitors, each with its own KVM.  The machine library dialog was coming up on a different display than the main F360 window, and that monitor was displaying a different computer's output.
So... this is no longer an issue.
