Fusion Manufacture
Extention update error
3 REPLIES 3
prodHN6FZ
115 Views, 3 Replies
Hello
Fix this IMMEDIATELY!!!
I've noticed a new "feature" in the geometry selection, when i extent geometry. This feature is apparently now something various cycles decide if they want to follow or not. This has caused collisions and made it necessary to sketch lines the tools are to follow instead. That update/change is utterly useless, why in the world would you update the CAM to something less usable in manufacturing?
Now i would just like to know who you guys think should pay for reprogramming several CAM programs that otherwise worked perfectly?
Very angry regards
3 REPLIES 3
seth.madore
in reply to: prodHN6FZ
Can you provide examples of where it's failing? (it's known(and being worked on) that Wrap contour does not obey extension values)
Seth Madore
prodHN6FZ
in reply to: seth.madore
Sure
I'll provide two pictures to clarify, in these particular pictures it was a 2D Trace cycle that messed up. Before, the start and end had extended start (0,5) and stop(2,0), to be able to adjust the off-angle chamfer at the machine to visually look okay. Please note that this is the 3rd time since the update, that this new "feature" has caused severe problems and it hasn't been limited to 2D Trace
Why not just rollback the update since it obviously wasn't properly tested before release, then fix these issues before re-releasing? We have started to rely on Fusion as our CAM software and incorporating it in everyday use, issues like this isn't something professional machineshops want to deal with
seth.madore
Correct; Trace also does not obey the defined extension values. We have tickets open on that as well and are working on a fix.
Seth Madore
