Fusion Manufacture
extend 2d contour
7 REPLIES 7
Message 1 of 8
tomQRBHJ
212 Views, 7 Replies
extend 2d contour
as you can see on the image is that i want to extend my contour because i want to mill the corner in the next setup, and also skip the holes. i tried to extend it with "to boundary" with no succes. is there a option to extend or skip it or will i have to use another milling feature.
Tags (2)
7 REPLIES 7
Message 2 of 8
Hi, you can limit the border you want by sketching in the Design section.
Message 3 of 8
weber_dominic
in reply to: tomQRBHJ
You can just add the desired extension length.
For a nicer way, i would just sketch a rectangle in the right size and choose that as your contour.
Message 4 of 8
tomQRBHJ
in reply to: weber_dominic
first off all, thanks for the reply 🙂 i tried the first option you gave me but it said that it has no passes to link...
Message 5 of 8
i think 1 sketches solves all problems 🙂
Message 6 of 8
weber_dominic
Oh yes my bad! Then go with option two and draw a rectangle around.
Message 7 of 8
true that, it works like a charm. something for autodesk to evolve in. many thanks 🙂
Message 8 of 8
programming2C78B
Select the two blue lines seperately, then in the 2nd tab adjust their start/end tangential extensions until they mill into the vertex of the corner.
Please click "Accept Solution" if what I wrote solved your issue!
