Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Exporting Build Files for Anycubic M3 Plus
billjXKYEK
billjXKYEK
We recently purchased an Anycubic M3 Plus SLA printer here, and the printer itself is working beautifully, but I'd like to be able to use Fusion to generate supports and create build files, as the included software is far less friendly and has some weird interactions with designs - tends to create very low polygon versions of models.
The only Anycubic SLA printer in the Fusion library is the smaller Photon Mono - so I copied the machine file and customized it for the larger build volume and print parameters.
However, when I move to create a machine build file, it prompts me for an exporter - and the only selection available is Anycubic PWMO, which is the Photon Mono's exporter. I cannot for the life of me find any information about what this "exporter" is, where this exporter is stored if I wish to edit it, or where to find one for the machine I do have. Making a machine build file with this exporter gives me something with an incorrect origin (no matter how much I edit the platform origin dimensions in the machine library, it's always out to lunch,) and the machine's software hates it.
Does anyone have any insight into the nature of this Exporter?
thomas.stock
Hi @billjXKYEK ,
Hmmm yes so I believe that we would need to add the exporter for the Anycubic M3 Plus. Currently it seem we do not make this exporter/ postprocessor available for users at the moment. The only postprocessor in the post library is for the Anycubic FFF machines.
A possible workaround could be to export your part with the Fusion supports as a 3MF and then import this file into the Anycubic Slicer:
Let me know if this helps.
If my answer has helped you, please click "Accept Solution".
If not, please reply back and tag me.
Tom
Fusion Additive Team
billjXKYEK
Thanks for getting back, Thomas - at least now I know. I'll give that a
shot and see if I can work with that, but I hope we can get that post
processor soon.
