Fusion Manufacture
Export colour, flexibility and texture to .3mf for 3D printing on Stratasys J750 polyjet
6 REPLIES 6
Ph!l
806 Views, 6 Replies
Could someone outline the process to do this please? Is it possible using and education license of Fusion?
6 REPLIES 6
thomas.stock
in reply to: Ph!l
Hi @Ph!l ,
Sorry no one has answered your question!
It is possible, but the "export as .3mf" option is only accessible through the manufacturing workspace, having created an additive setup - see attached imaged
I recommend an FFF setup to do this. If unsure how to create one, please follow the following video (you only need to watch until 00:59):
https://www.youtube.com/watch?v=Nf2RTgoI5L8&ab_channel=AutodeskFusion360
After that, you will see you "export as .3mf" option available under the 'Actions' tab in the ribbon (indicated by the red "2" drawn in the attached image).
Let me know if you have any issues
If my answer has helped you, then please click "Accept Solution"
If not, feel free to reply back and tag me
Tom
Fusion 360 Additive Team
thomas.stock
in reply to: Ph!l
Hi @Ph!l ,
Unfortunately I have some bad news..
At the moment we do not support the export of parts with textures or colours, even via the "export as 3mf" option detailed above.
Apologies for this.
Tom
Sualp.Ozel
in reply to: Ph!l
You can do this using Fusion + Autodesk Netfabb Premium
They are both available to EDU users.
Sualp.Ozel
in reply to: Ph!l
And here is a video on how to do this.
tallman5
in reply to: thomas.stock
@thomas.stock - If I go to Design workspace -> right click a component -> Save as Mesh -> Choose 3MF file format, the 3MF does have the material color info. If I go to Manufacture -> (with full setup) -> Actions -> 3MF Scene Export, the 3MF does not have the material color info (all models are gray).
Is this behavior correct? If so, any plans to add colors to the Manufacture export?
Thanks!
thomas.stock
in reply to: Ph!l
Hi @tallman5 ,
Yes this is the correct behaviour. Exporting a 3MF from the manufacture workspace with colour is something we are looking into.
Tom
