Excessive code output
halejoshuas1
halejoshuas1
I am using the generic fanuc turning post and I keep running into instances where, for instance i am machining a .375" radius but my code outputs a series of alternating g3 and g1 at varying increments..I guess technically the output is correct but it makes any hand modifications very cumbersome. Can anyone point me in the direction of a way to cut down the code and still maintain dimension?
halejoshuas1
The archive file is attached. i am also having trouble with the spun profile for the turning op.it doesnt seem like it is actually turned, just a revolved cross section.
