Fusion Manufacture
Error
9 REPLIES 9
Message 1 of 10
7732990
177 Views, 9 Replies
Error
Hello guys,
My question concerns an error that occurs in the manufacturing section, when I program a contour or hole and start the simulation, the program does not recognize its geometry. I leave a print so it can be easier to understand
9 REPLIES 9
Message 2 of 10
lucasliraAU
in reply to: 7732990
@7732990
Hello
Could you share your file in (f3D) on your last try, so I can open it here and run some tests.
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
Message 3 of 10
7732990
in reply to: lucasliraAU
Sure, take it.
Message 4 of 10
@7732990Firstly, Welcome to the community !!
Coming to your query, I can see your model has cleared all the contour's. So where exactly are you stuck?
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 5 of 10
I have already tested it and when I sen my file (f3d) to another person and she performs the simulation the contours are correct but in my account it is wrong, as I sent previously.
Can you help me?
Message 6 of 10
In my account the contours still like this
Message 7 of 10
@7732990, I think this could be a graphics issue.
Thanks and Regards,
Rushabh Thakkar.
Message 8 of 10
But do you know how to fix this?
i relly appreciate it
Message 9 of 10
baibulayev1207
Message 10 of 10
seth.madore
It's not a graphics issue, you have the Accuracy Slider in Simulation turned down really low.
Seth Madore
