- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I sent a picture of this message in case it helps. This is the message:-
Error: You must set 'highfeedrate' because axes are not synchronized for rapid traversal. Error at line: 579
I get this message most mornings after posting a program, not the first time, but the second time strangely enough. The first post process always is successful, but when I try post a second time, I get this message. It doesn't matter if it's for the lathe or the mill. The only thing I can do is shut down Fusion360 and restart it again, and usually, this fixes it. Occasionally, I will have to do this twice. Once I had to do it three times. This problem began with the last update when those really handy incremental buttons were removed (which I hope get re-instated.)
Fusion
