Error with gcode or fusion post process. Not sure
cruzhr657
cruzhr657
So I'm using a Republic Lagun Sinumerik 828D. My issue is that at the end of running the entire code just fine it wants to do a tool change (M01) even though that isn't included in the Gcode. This only started happening after the last update I did to the fusion360 software. Before then it always ran and stopped fine.
Do I need to adjust something in the 'Post Process Properties' for this to not happen??
a.laasW8M6T
so I'm not Familiar with Siemens, but it could be to do with the Safe retracts being set to SUPA, I doubt its actually trying to do a tool change though. it just affects the retract behavior. Try setting it to G53 instead?
Also M01 isn't a toolchange code it is an Optional stop ,tool change is Typically M6 but some controls don't require this and will execute a toolchange on the toolcall.
Andrew Laas
Senior Machinist, Scott Automation
hyperbolicindustries
? what your showing shows a homing line (SUPA A) and M30 for end of program. Does not so M1 (optional stop) anywhere.
cruzhr657
It shows it on the display screen not the on the actual gcode. The end of the gcode just shows M30
But this has been happening on the last few times I've used the machine.
