Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Error "Location is not writable" in Post Process window
4 REPLIES 4
m.wuendsch
316 Views, 4 Replies
I have a problem in the Post Process window:
I can select a folder and save the NC-Programm wherever I want but when the folder path contains a ä, ö or ü in its name I cannot look at the content of the folder.
Can you please add those characters to the acceptable folder path name list?
Best regards
Michael
4 REPLIES 4
Thank you for report. We'll take a look into the issue.
Viacheslav Shapilov
Developer Technical Services
Autodesk Developer Network
ltomuta
in reply to: m.wuendsch
This post is old but it looks like the issue is already solved
m.wuendsch
in reply to: ltomuta
I'm on V.2.0.15027 and still have the problem. The problem is not the writability.
I can export the .nc-code BUT I cannot use the "open output folder" funktion that is covered up by the yellow/orange circle with the exclamation mark.
Maybe the problem is only an errormessage that is no longer needed and needs to be removed.
Sincerey
Michael
ltomuta
I see. Indeed, I can also reproduce the problem now when using special characters from the Romanian alphabet.
