Error occured during stock calculation
tgford58
tgford58
https://a360.co/3tKEUcV
Attached is a file that I am trying to work through.  I continue to get the error message.  I know that the grooving tool is causing the problem but I have tried everything that I can see.  Sometimes it will run the tool but it does not remove material in sim.
Can someone help me figure this out please?
seth.madore
It's because of your tool. Change the Head Length to a smaller value than the Overall Length:
Seth Madore
akash.kamoolkar
@seth.madore what Seth said. Also, in an upcoming update we will be validating the tool upstream so you'll immediately know if you've set the correct tool parameters instead of getting this goofy message way downstream.
Akash Kamoolkar
Software Development Manager
tgford58
Aaaaaa!  I knew that.
Thank you for taking the time to help me.  It is greatly appreciated.
tgford58
Fantastic.  It just keeps getting better and better.
akash.kamoolkar
FYI,
This issue was fixed in the update that recently went out.
Akash Kamoolkar
