Hi!
I have this error
and in the vendor description i have this
What should i do?
Hi!
I have this error
What should i do?
Turret number needs to be one of those listed in the error. You can change that value in the Tool Library where you assign Tool/Turret numbers.
Turret number does not refer to the station on the turret, but is used to define things such as gang tooling positive/negative position
