!Error: Failed to post data. See log for details.
I am running a fanuc 18m controller on a leadwell v30,   i can not get the software to post my g code, useing the fanuc processors ;  dont know what its telling me.
Information: Configuration: FANUC
Information: Vendor: Fanuc
Information: Posting intermediate data to 'C:\Users\xxxxxx\AppData\Local\Fusion 360 CAM\nc\1.nc.failed'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Thursday, June 14, 2018 6:22:24 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41970
Configuration path: C:\Users\xxxxxx\AppData\Local\Autodesk\webdeploy\production\8cfd92dd610d300b879a5bcad49d7d443f6d1533\Applications\CAM360\Data\Posts\fanuc.cps
Include paths: C:\Users\xxxxxx\AppData\Local\Autodesk\webdeploy\production\8cfd92dd610d300b879a5bcad49d7d443f6d1533\Applications\CAM360\Data\Posts
Configuration modification date: Saturday, June 02, 2018 11:55:06 AM
Output path: C:\Users\xxxxxx\AppData\Local\Fusion 360 CAM\nc\1.nc.failed
Checksum of intermediate NC data: 8d49ef684e656cbf64ba98a2bed3891b
Checksum of configuration: 1ebb473c4796c24a82fb7dfd2022e960
Vendor url: http://www.fanuc.com
Legal: Copyright (C) 2012-2018 by Autodesk, Inc.
Warning: Multiple work offsets used in program.
Generated by: Fusion 360 CAM 2.0.4233
Error: The depth is invalid.
Error: Failed to execute configuration.
Stop time: Thursday, June 14, 2018 6:22:24 PM
Post processing failed.
LibertyMachine
Could you share your Fusion file here?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
randyT9V9C
The "Error: The depth is invalid." makes me suspect you have a positive number for the depth on your first operation, likely a drilling op. Make sure you have setup a valid WCS and have your cut depth heading in the correct -Z direction. :winking_face:
Thanks, I was starting in the matl. And feeding up somehow.
aldunlop
I have had this error a few times where there is nothing in the log file.
Details: Engraving; Tormach; tool number 553 is the latest example.
This only took 1.5 hours to figure out.  An error message sure would be nice...
