Fusion Manufacture
Error: Failed to export rest material
6 REPLIES 6
rhetths
345 Views, 6 Replies
Geez.
Cant bore a couple of holes.
6 REPLIES 6
rhetths
in reply to: rhetths
Christmas tree now
rhetths
I turned on "In Process Stock" and the problem appears to have gone away.  Wasted a chunk of my time.
rhetths
I think i saw my CNC machine perform a rest machining manouvre yesterday.  Has turning on "In Process Stock" made my machine perform rest machining?
seth.madore
When you say "My machine", do you mean the computer you're running Fusion on, or the actual CNC machine in your shop?
Whatever is happening at your machine is first shown in Fusion (for the most part, there are some oddball exceptions).
IPS has little to do with Rest Machining, it's mostly a graphical display of your in-process stock to help eliminate bouncing between programming and simulation
Seth Madore
rhetths
in reply to: seth.madore
I was intending to refer to the actual CNC machine in my shop.  I was expecting it to perform a ramp spiral down, then 2D adaptive clear a pocket, but I had already had it drill a hole and it seemed to plunge straight down the hole then machine the pocket.  The hole was in the same location as where i expected it to ramp spiral down, but it happenned super quickly, in the blink of an eye, and did not seem to spiral.
seth.madore
Can you share the file that produced this result? In Fusion, did you witness it spiraling down, or was it a plunge move?
Seth Madore
