Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Error: Failed to export rest material.
2 REPLIES 2
serviceT7GZW
294 Views, 2 Replies
I am getting this error.
When i run a simulation i get this error. An error has occurred during stock calculation.
Any solution to this?
I already turned checked (in process stock- mesh check safety) in my preferences and that made no difference.
2 REPLIES 2
seth.madore
in reply to: serviceT7GZW
Your tool has an impossible definition. You've got a width of .79mm, but corner rads of .80mm. If it's a full radius insert, you should define it as a Round insert. Otherwise, set it to the proper value and the warning will go away
Seth Madore
serviceT7GZW
in reply to: seth.madore
That was it! Thanks for your help.
