Error: Cannot load machine model
componentscience
componentscience
This error seems like a bug. It's complaining about a link to a machine model. Edits were made in the 'Machine Builder' while the file was opened. Specifically the Tool and the Part attach points. Fusion also started crashing during this process which points towards a bug.
Regardless we removed the machine model completely from the setup as shown and re-generated the toolpath. It still complains. Also tried restarting both Fusion and the PC but no luck.
If you feel your question was answered, please accept it as a solution. Thanks!
a.laasW8M6T
Hi
Try removing the Machine from all setups, then go to the machine library and delete it from the Document, then re pick in the setup from the Machine library
Andrew Laas
Senior Machinist, Scott Automation
componentscience
That worked thank you!
a.laasW8M6T
I just had a thought that maybe you just needed to update the model?
I'm not sure I have not come across that error before
Andrew Laas
LukeMahler
this is exactly what I needed! thank you! I couldn't figure out where else in my file the machine was linked (I only have one setup) but this was perfect for helping me know that it saves it in "document"
