Fusion Manufacture
Entry Point Help
11 REPLIES 11
Message 1 of 12
drewscha
288 Views, 11 Replies
Entry Point Help
 Nothing works when trying to clear out and mill this channel. Any tips would be great. Lots of empty toolpaths.
11 REPLIES 11
Message 2 of 12
seth.madore
in reply to: drewscha
Adaptive toolpath with a .01" endmill? That seems a bit.....abusive to the machine.
Could you share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 12
drewscha
in reply to: seth.madore
Message 4 of 12
seth.madore
Your tool is .01" in diameter and your slot is .0118" in diameter. Adaptive is not the toolpath to be using, as there's effectively very little room for movement. I would use Slot (with a sketch) or 2D Contour and small depths of cut axially. Depending on the material, I might want to go .005 to .01"
Seth Madore
Message 5 of 12
drewscha
[image: Screen Shot 2023-06-22 at 1.35.19 PM.png]
I tried 2d and it cuts into model for some reason.
Message 6 of 12
seth.madore
I'm not seeing an image. Could you share your file again?
Seth Madore
Message 7 of 12
drewscha
Yes, thank you for your help btw. https://a360.co/43RvBIR
Message 8 of 12
seth.madore
Don't select the face of the pocket, select the inside bottom edges. Result:
Seth Madore
Message 9 of 12
drewscha
Thank you so much!
Message 10 of 12
drewscha
Did you just do 2dcontour>chain> closed loop> ok? I get errors when doing this.
Message 11 of 12
seth.madore
Just select the inside edges:
Seth Madore
Message 12 of 12
drewscha
You are a legend.
