Fusion Manufacture
Entering factional inch tool dimensions converted incorrectly to metric
4 REPLIES 4
jerry.jose
157 Views, 4 Replies
Bug: When adding or modifying tools while in "inch" unit format, inserting in fractional values to the tool seems to mistakenly convert the value to metric. So a 7/64" tool is changed to a .0043" tool.
Only indication something is wrong on this screen is the previewOnly indication something is wrong on this screen is the previewClicking on the dimension in question shows the correct unit and fractionClicking on the dimension in question shows the correct unit and fractionThe tool library shows the altered dimensionThe tool library shows the altered dimension
4 REPLIES 4
seth.madore
in reply to: jerry.jose
Hmm. I just tested this on my end, and it's working as expected:
Are you up-to-date on Fusion?
Seth Madore
jerry.jose
in reply to: seth.madore
Yes, I am on Fusion 360 2.0.15299 x86_64. I entered in a decimal value and then a fractional value. the preview did not change, but when I hit enter, the preview in the Tool Library updated to show the metric size tool. In this instance, the tool library is also showing the previous "inch" diameter value.
seth.madore
Would you be able to capture your steps in a screen recording, by chance?
Seth Madore
seth.madore
Are you using the Insider Program version of Fusion? There's a Preview Flag that controls this, and it's expected behavior
Seth Madore
