Fusion Manufacture
Enhanced path generation for undercut areas.
2 REPLIES 2
monozukuri.daisuki.higucchan
120 Views, 2 Replies
When using flow, morphing, and scalloping paths using the 5-axis function, it is only possible to generate paths in the visible range, so in the future I would like to be able to generate paths in areas that are undercut without modifying the model.
2 REPLIES 2
Flow can machine undercuts in 5 Axis already so can blend, but you must use a Spherical tool(Ball nose or lollipop)
also you can use Steep and shallow and geodesic to machine undercuts.
I don't think scallop and morh will get the ability to do undercuts(but i may be wrong)
see examples in attached file:
Thanks for letting me know.
I look forward to future enhancements to Fusion360!
