Engraving width limit of 0,5 mm
goran_G
goran_G
Is there any option to remove the engraving width limit of 0,5 mm?
I mean, the engraving setup is soo....lucking of.....everything. Can I engrave this with another setup, the tool is a V-bit (90° or 60°)?
seth.madore
What tool definition do you currently have? Is your bit defined to a sharp point, or is there a flat?
Can you share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
goran_G
Thank you for your fast replay. As I said, it's a V-bit, so it's sharp 90°.
And here's the file...
seth.madore
It's not actually defined as a sharp tip.
Set that to zero :slightly_smiling_face:
Seth Madore
goran_G
Ok thank you, that's my obsession with "everything must be perfect!". I remember measuring that bit for 10 minutes.
But anyhow, that engraving setup need some features. Couldn't you just copy some code from the defunct Artcam? Those are mostly math formulas. I played a few weeks with Artcam and was a delight for woodworking.
