Fusion Manufacture
engraving intersecting lines
7 REPLIES 7
Message 1 of 8
ali_agan
198 Views, 7 Replies
Hi All,
I'm bit newbie, trying to engrave a name but i couldn’t figure out how to cut intersecting lines. Can you guys show me how to cut continuously. Please find attached photos to see what i mean.  Thanks in advance.
7 REPLIES 7
Message 2 of 8
HughesTooling
in reply to: ali_agan
Can you export your f3d file and share here please?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
ali_agan
in reply to: HughesTooling
please find attached f3d file.
thanks
Message 4 of 8
HughesTooling
Do you want to use cutter compensation and offset by the cutter radius? Usually people use centreline cutting as it's easier to sketch.
Mark Hughes
Message 5 of 8
ali_agan
i'm trying to make neon signage so i need 8mm centre line cut with specific 8mm bit as below.
Message 6 of 8
HughesTooling
OK, then all you need to do is set Compensation to off and it should work. You can also use trace for centreline cutting. See attached file for examples of both toolpath types.
Mark Hughes
Message 7 of 8
HughesTooling
One more bit of advice. When selecting a chain of profiles, select the first line, click a second time on the line and you get the option to add more curves to the selection.
Mark Hughes
Message 8 of 8
ali_agan
thank you so much
