Fusion Manufacture
Engraving gcode error - entry and exit marks
11 REPLIES 11
Message 1 of 12
Natalie_CKD
219 Views, 11 Replies
I just started to use fusion for plastic engraving with a CNC. The gcode exported from fusion has these entry/exit lines that drags along the plastic which isn’t found in the fusion drawing. Any ideas what I’m doing wrongly?
11 REPLIES 11
Message 2 of 12
HughesTooling
in reply to: Natalie_CKD
Really need more info, can you share the f3d file?
One thought is have you got keep tool down checked? Try unchecking it.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 12
seth.madore
Do you have your heights set correctly at the machine?
Seth Madore
Message 4 of 12
Natalie_CKD
Hi @HughesTooling
Checking my setups, the "keep tool down" is unchecked.
I created another file with a simple box and circle, and its still showing these "unwanted" engraved lines. When simulating on Autodesk Fusion the path seems correct, however upon exporting .tap to Mach3, the g-code shows this on Mach3 screen:
Attaching files here for reference.
Message 5 of 12
Natalie_CKD
Hi @seth.madore
The heights for the engraving text & lines are correct and reflected correctly when engraving. I cant figure out why the gcode exported from Fusion360 adds this additional "unwanted lines'. I had a friend create a similar design on ArtCam and exported to gcode. I then used this file to upload to my Mach3 and it doesn't have this issue.
Thanks!
Message 6 of 12
seth.madore
@Natalie_CKD what post processor are you using, can you share the code that you were getting?
I just posted this out with the Mach3 post processor, and this is what I'm getting:
Seth Madore
Message 7 of 12
Natalie_CKD
Hi @seth.madore
Attaching the g-code exported as .tap from Fusion360 - uploading the .txt file here (unable to upload .tap to this thread).
I'm using Mach3mill. May I ask what Mach3 post processor application you are using?
Message 8 of 12
seth.madore
It's not a Mach3 screen that I shared with you, it's what is referred to as a "backplotter" (I use Cimco Edit).
Now, can you share the code that your friend gave you? (your code looks the same as what I showed earlier, and is correct, by all accounts)
Seth Madore
Message 9 of 12
HughesTooling
in reply to: seth.madore
Is this the old G28 problem on a machine that hasn't been homed?
@Natalie_CKD There are options on the post dialog for different retracts but I'd recommend setting your machine home position and using G28. Some info on G28.
Mark Hughes
Message 10 of 12
seth.madore
in reply to: HughesTooling
It does sound like it
Seth Madore
Message 11 of 12
Natalie_CKD
Hi @seth.madore  and @HughesTooling
Finally received a reply from my CNC machine seller. He stated that the CNC machine supplied is to be used with Mach3 Mill + ArtCam thus he is not supporting my inquiries for Fusion360 + Mach3 Mill.
I tried using Artcam and it does not have the same issue as what I'm facing with described above in Fusion360. There must be some machine settings / home settings that I'm missing out?
Message 12 of 12
HughesTooling
A lot of the cheaper CAM systems do not use G28 for tool changes, bit amateurish really!
The problem you're reporting comes up all the time and is because you're not setting the machine home position. Usually you would have limit switches and home the machine but most of the Chinese machines don't bother. If you do some research you can find out how the set your machine home position(G53). You should then set you job using G54 as your origin.
If you want to just bodge it you also have the option to do it the same way as ArtCAM.
On the post dialog there's an option for safe retracts, you can select clearance height but be careful as you can run into problems with tool changes and also run the risk of running the machine into the mechanical limits. Personally I'd recommend buying and fitting limit switches and doing it the right way.
Mark Hughes
