Fusion Manufacture
Engrave issue
2 REPLIES 2
jscott6SWZG
176 Views, 2 Replies
Engrave issue
First time using engrave....on a finished part.
In manufacture
set up binding top
Toolpath T10 engrave2
I selected the letters, all highlighted, oked it
but it did not pick up the last letter i.....I have another i it did pickup...
I simulated it and all the other letters appeared to cut.
I then tried to select the bottom contour of the last i  and it worked.
So which is it select dilegently select bottom contours.....or just select letters.
2 REPLIES 2
rengfx
in reply to: jscott6SWZG
That's a curved surface so a 2D toolpath like Engrave will cut each letter differently as it's going to a consistent depth but because of the curve will look different
Trace would be the toolpath to use as it will cut along the variable Z level, but it doesn't work well in my experience outside of Line Fonts as with that kind of font it will only cut outlines
jscott6SWZG
yeah was going for the outlines
anyway ill try trace
worked perfect select bottom of contour like always......
thanks alot
I wonder why it is not in 3d catagory rather than 2d catagory.....i might have even picked it.
