Fusion Manufacture
Engrave depth dips at junctions
7 REPLIES 7
Message 1 of 8
gsaDO
211 Views, 7 Replies
Can anyone suggest what's going on here?
The depth dips at all junctions and on the "4" for some reason.
I also can't figure out what this message is about.  I saw in another post that George Roberts explained how to change the "chaining tolerance" and reducing it from .0004" to .0002" or smaller fixed it, but it's it about?  That's some tiny little factor.  It fixed the larger issue with the "4" but not the junctions.
7 REPLIES 7
Message 2 of 8
seth.madore
in reply to: gsaDO
Thanks for bringing this to our attention! It does appear that this is something that needs to be investigated. To clarify; this was a native Fusion font, right?
As a workaround, you were on the right track with the Extrude command. You can then select all the contours (one by one, as "Face Selection" is picking up incorrect contours).
However, another method, and this may or may not appeal to you; use a "stick" font and use Trace instead
Seth Madore
Message 3 of 8
gsaDO
in reply to: seth.madore
Yes, it is a native font.
Message 4 of 8
seth.madore
in reply to: gsaDO
I've logged this as CAM-44015, thanks for reporting it. We'll try to get this investigated!
Seth Madore
Message 5 of 8
HughesTooling
For the cutter used this looks correct with the setting of -0.02 for the bottom depth.
You can see in the narrow section the cutter can only go to -0.0078" and in the intersection there's more room so the cutter goes to -0.01847. So for this font and this cutter you need to set the bottom height to something like -0.007 to get a more constant depth and no plunges at intersections.
This is what I see using -0.007 for the bottom height. Still some places where the cutter can't reach -0.007 but a lot better.
Mark Hughes
Owner, Hughes Tooling
Message 6 of 8
gsaDO
in reply to: HughesTooling
Thanks Mark.  Good catch.  How do you pull up the step by step toolpath information?  I've never encountered that.  You can't get tool depth information in the simulation, right?
Also, I appreciate the instructional videos you put out.  I find them to be really concise, with a level of detail that really works for me.
Thanks.
Message 7 of 8
HughesTooling
in reply to: gsaDO
@gsaDO If you right click an op you get an option to show toolpath data.
@seth.madore Been meaning to bring this up for a while, always seems strange there's no view data if you right click the toolpath info under an op. Could the view option be added, not like there's a lot of option on this menu at the moment!
Mark Hughes
Message 8 of 8
gsaDO
