Empty tool path
Empty tool path
Hi All
I am new to Fusion and I am having a hell of a time
I am doing one of the exercises in the learning videos In fundimentals of milling and i keep getting empty tool path
When the model is turned upside down and trying to rough pocket holes and pocket
I cannot work it out
Any help would be appreciated
jari.peltola
The problem is that the helical ramp is tool large to fit in the pocket. In the "Linking"-tab you can adjust the "Helical Ramp Diameter". Also the "Radial Stock to Leave" parameter in the "Passes"-tab affects to the result.
I think that ½inch tool is a little bit large for the "rough circle pockets" which have only 0,626" diameter and you also want to leave some stock for finishing. You could consider using the 3/8 tool instead.
But anyway, tuning those two parameters you should be able to get forward.
Br. Jari
Thank you very much that has fixed the problem
Ivan
