Fusion Manufacture
Empty Tool Path, Adapative Operation
2 REPLIES 2
howardkinkade
59 Views, 2 Replies
I can not figure out why I keep getting an 'empty tool path' in the first adaptive clearing operation in the attached file.  I added a facing operation at the beginning and edited the adaptive operation, but I can't figure out what I did wrong.  Any help is much appreciated.
2 REPLIES 2
a.laasW8M6T
in reply to: howardkinkade
That's because there is nothing to machine, you have covered up the cavity in your part with a solid top(green)
adaptive cannot "see" anything below that top piece
If you remove the solid top piece then it will generate fine
Perfect, thanks for the lesson.
