Fusion Manufacture
Edit 'Feed preset' not showing in 'Compare and Edit'
2 REPLIES 2
102 Views, 2 Replies
I'm noticing that whenever I want to edit the feed preset it won't change the 'value' in the compare and edit dialog box
It'll change the values like it needs to. But now i'm still double checking it by opening the toolpaths. I'd like to see it shown in the compare and edit window
2 REPLIES 2
programming2C78B
Because compare and edit isn't a 'live' viewer. Changes don't apply until you accept them and regenerate.
Apply your changes and then compare them again.
Please click "Accept Solution" if what I wrote solved your issue!
in reply to: programming2C78B
in other cases the settings will change. In my case it will still be showing 'click to select'.
