Edit a machine for the setup sheet. For configuration the Emco Concept mill 55
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, can someone explain to me how to configure Emco Concept mill 55 data step by step. Is it confusing for me?
Data Emco Concept mill 55:
Travel in X longitudinal 190 mm (7.48")
Travel in Y latitudinal 140 mm (5.51")
Travel in Z vertical 260 mm (10.24")
Effective Z-stroke 120 / *190 mm (4.7 / 7.5")
Distance spindle nose - table 77 – 337 mm (3.03 x 13.26")
Table
Clamping area (L x W) 420 x 125 mm (16.54 x 4.92")
Max. table load 10 kg
2 T-slots DIN 650 11 mm (0.43")
T-slot spacing 90 mm (3.54")
Milling spindle
Bearing type roller bearing
Tool change (Option)
No. of tool stations 8
Max. tool weight 1 kg
Max. tool diameter 40 / *60 mm (1.6 / 2.4")
Motion speed tool swivel arm 10 m/min (0.39 ipm)
Tool clamping automatic
Milling spindle drive
Motor power 3 phase asynchronous motor 0,75 kW
Speed range 150 – 3500 rpm
Max. torque 3.7 Nm (2.72 ft/lbs)
Speed with optional engraving spindle 14000 min-1
Feed drive
3 phase step motor in X / Y / Z axis 0,5 µm / 0,5 µm / 0,5 µm
with resolution
Rapid motion speed and feed rate X / Y / Z 0 – 2 m / min (0 – 78.74 ipm)
Average positioning variation in 8 µm / 8 µm / 8 µm
VDI/DGQ 3441 in X / Y / Z
Feed power X / Y / Z [N]“ 800 / 800 / 1000
2) I have the solids of the clamp jaw and the table. How can I use it in setup? Can I add it to the configuration of my machine?
3) How to configure the holders? To use the SK-30 cones in my tool store.
Fusion
