Easy way to Fold out a pipe
joakim.jfab
joakim.jfab
Lets say im making a tube chassis or just a frame with either round tube, or square tubing.
I know im not the only one who is missing an easy way to fold out this pipe to to then save as DXF and then cut this out on a CNC Plasma or laser tube notcher. I know i can do this by making a cut all the way length wise on the tube, and then convert to sheet metal, then make flat pattern, but there should be a function to just select a tube og square tubing inside sheetmetal workspace and just make flat pattern of the selected tube.
jake2QSUB
Community Visitor
Community Visitor
Agreed! But why stop there? It would be nice to be able to export the bent components to have the tubes CNC bent as well.
joakim.jfab
Yes @jake2QSUB  :slightly_smiling_face: And maybe a fuction to straighten out bent pipe :slightly_smiling_face: Or if we could just get a Roatary plasma tool, that would help ALOT!
