Dynamic/linear broaching
banddspindles
Message 1 of 23
banddspindles
Can one of teh fusion 360 engineers please create a drill cycle for dynamic broaching.  It would require a spindle orientation m19, a stepover, and a away from wall shift.  I have read how some inventor users had their engineers change one of their not used drill cycles(back boring) and convert/create a broaching drill cycle.  Can we please get help on this.  Also, we need a way to create square tools in the library such as broaches for milling, so we can simulate the toolpaths and cycles.
Replies (22)
Message 21 of 23
michael.grenier4GVTU
I did look into the Haas NGC post with inspection we have that is supplied with the fusion installation and integrating the custom variable in this one would be a much bigger task.  The thing is, those custom parameters are pretty new and most post do not support them yet.  To make them support it, we have to re-write the entire properties definition block and change the way those parameters are called everywhere in the post.  On a simple post like the mach3 one, this is fairly easy, but on a post like the haas NGC, it's much more complicated.  It is feasible but I think you should wait for post properties to be spread in this post, then you can simply add a couple lines to the post and it will work.  I don't know when this new capability will be spread though.  You can compare the mach3 post I did with the original one that was supplied and I'm pretty sure you'll understand what needs to be done and why it is more complicated in the haas post.
Michael Grenier
Senior Solution Engineer
Message 22 of 23
Fabbunny69
Big thanks go to @michael.grenier4GVTU  and @Anonymous.
I used both solutions together and now have very good broaching possibilities in Fusion.
Message 23 of 23
jens_kristian94
Could you please help me modify this post to use the fine boring-shift toolpath to do broaching?
