Fusion Manufacture
Drilling feed per revolution
1 REPLY 1
marshallt179
131 Views, 1 Reply
I appreciate that Autodesk heard the frustration of many about the missing feed per revolution in the drilling tab and took action but they fell short on reinstating it. It appears that checking the "Use Feed per Revolution" box does toggle the feedrate between FPM and FPR but the two values are not linked. A better solution would be to allow both fields to be functional/editable at the same time but associated with each other, just like Spindle Speed and Surface Speed are associated. The "Use Feed per Revolution" checkbox would then be used to determine how to output the code. If I am not mistaken, I believe this is how it was in older versions.
1 REPLY 1
seth.madore
in reply to: marshallt179
Yep, it's not linked. We've heard similar feedback from multiple sources and are discussing what our next steps should be. Thanks for your input! 🙂
Seth Madore
