Fusion Manufacture
Drill Cycle Circular Pocket Milling No Plunging Feed Error
5 REPLIES 5
haveoneforme
235 Views, 5 Replies
Fusion 360  output code is now alarming out in the CNC machine control when the Drill Cycle "Circular Pocket Milling" option is selected, using a Heidenhain Control.
The problem is the drill cycle is no longer giving an option to assign a plunge feed.
When the code is posted the control alarms out when the plunge feed defaults to zero
See below
5 REPLIES 5
seth.madore
in reply to: haveoneforme
Hmm. Which post are you using? I just quickly tested with the Heidenhain 426 and am getting this:
9 * - Drill1
10 M5
11 TOOL CALL 1 Z S14500
12 L M140 MB MAX
13 M3
14 L X+6 Y+18.3333 R0 FMAX
15 L Z+0.84 R0 FMAX
16 CYCL DEF 32.0 TOLERANCE
17 CYCL DEF 32.1
18 CYCL DEF 208 BORE MILLING ~
  Q200=+0.1 ;SET-UP CLEARANCE ~
  Q201=-0.74 ;DEPTH ~
  Q206=400 ;FEED RATE FOR PLUNGING ~
  Q334=+0.04 ;INFEED DEPTH ~
  Q203=+0.74 ;SURFACE COORDINATE ~
  Q204=+0.1 ;2ND SET-UP CLEARANCE ~
  Q335=+1 ;NOMINAL DIAMETER ~
  Q342=+0.5 ;ROUGHING DIAMETER
19 L FMAX M99
Seth Madore
haveoneforme
Hi Seth
Our post is about 7 months old, I've attached it, we just change a few coolant codes and renamed it to suit the machine.
I used this cycle only last week before the last update and it allowed me to assign a plunge feed. When I now go back to the same file there is no option to assign a feed for plunging.
I did a fresh install of Fusion this week so that shouldn't be the issue. We have also used this post for the last 7 months so I can't see that being the issue. It's just Fusion isn't showing the plunge feed option for me if I select "Circular Milling" in Drilling
Can you send me a screenshot of your feed setting page for the sample code you sent? I want to see where you set the plunge feed.
Maybe I am missing the obvious.
haveoneforme
I've just uploaded a part of program that we posted before the last update and it shows the plunge feed at 350mm/min.
I have then reposted the code in Fusion after the update, with exactly the same settings and the feed is defaulted to 0mm/min with no option in Fusion to change it.
andytpks
I'm enter for write a new post about this issue with the last update... i use a lot of time this Circular Pocket Milling, and Parametric Feed.
Same issues of the other guy... later the last update. I hope in a resolution...!!!
I don't think is a problem of the post processor, is like fusion don't accept Parametric Feed with this process.
I use Okuma post for milling, but the same issues with other post processor i use.
seth.madore
Okay, I've done some investigation, and this is a known bug that was introduced in the Drilling toolpath. We've got a ticket open for this, CAM-42648
Seth Madore
