Fusion Manufacture
Drill Canned cycle = Possible to chamfer ?
6 REPLIES 6
bgarrington
268 Views, 6 Replies
Like bore milling in the Drill canned cycles, is there a way to enable chamfering a counterbore and determine a size similar to bore milling.
Would be nice not to have to go around clicking each edge of multiple holes and instead as you do in drill select certain sizes that are the same.
Possible on other cam software's I've used and looking for the same feature.
6 REPLIES 6
seth.madore
in reply to: bgarrington
In your Drilling "Height" tab, you can define Chamfer Width and Chamfer Diameter, does that help your task?
Seth Madore
seth.madore
Or are you referring to the 2D Chamfer toolpath itself? This may likely be possible thru the API, but that's well beyond my scope of knowledge..
Seth Madore
bgarrington
in reply to: seth.madore
thanks seth as always for the quick response.
hadn't noticed these options so will have a look into them
thank you
bgarrington
So to follow up, I tried the options but its not what I'm after
Basically if I call a template in and it had drill, counter bore and chamfer.
I have to go around each counterbore selecting the edges to chamfer which adds up and also run the risk of missing one.
In the other software, I  can call the template in and not have to go through selecting each edge to chamfer.
seth.madore
Do you have a sample file you could share so I can run a couple experiments on it?
Seth Madore
bgarrington
Basically I'm after the chamfer option in the drop down menu in the canned drilling cycles.
Say I wanted to chamfer the 3 small counterbores without having to go into 2d Chamfer and select each one.
maybe its not possible
Attached, thank you for your time.
