Fusion Manufacture
Doosan DNM post processor
3 REPLIES 3
hensonch.ch
163 Views, 3 Replies
We have a Doosan DNM 6700 Mill at work. It’s fairly new with the new fanuc controller. I was unable to get the machine to run correctly with the Doosan 3/5axis mill post in the Fusion library. Is this due to a mistake I may have made or is there a different post for it?
3 REPLIES 3
Garrett_Wade
in reply to: hensonch.ch
I've successfully run the same post on similar machines before. Can you be more specific on the issues you ran into on your attempts?
firedragon2
I'm having issues with the (dn solutions 3/5 axis doosan post) post as well it ads circular geometry in the corners of pockets and chamfers. I ran a haas post on the same part and the gcode comes out fine.
a.laasW8M6T
in reply to: firedragon2
Hi
Can you share a Fusion file that isn't working correctly with this post?
And share which settings you have in the post window?
