How to do i get fusion to use the sub spindle as a live centre, I select the option under use tailstock and then select In Sub Spindle but i can't get it to post anything to do with the B axis?
Please Help!!
Josh
Please Help!!
Josh
Solved by seth.madore. Go to Solution.
At this stage of Fusion Mill/Turn support, you're best served with some manual NC "passthrough" g-code.
Thanks mate, something is better than nothing. im still new to Fusion so i only learnt about that manual nc passthrough code.
