01:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a 3 axis router that homes to the back top right using limit switches. The Z axis can then be zeroed to the surface of the work piece.
Do I need to define the x,y home position of my machine in Fusion 360, or is this normally done in the post processor? (I will use Linux CNC)
If I do this in Fusion, how do I do it?
I am assuming that the g-code generated by fusion needs to have it's 0,0,0 to be the same 0,0,0 as my CNC machine, or a least that sounds the most logical way to do things to avoid confusion.
I am new to CNC btw.
Fusion
