Do I define the home position of my CNC machine in Fusion 360?
I have a 3 axis router that homes to the back top right using limit switches. The Z axis can then be zeroed to the surface of the work piece.
Do I need to define the x,y home position of my machine in Fusion 360, or is this normally done in the post processor? (I will use Linux CNC)
If I do this in Fusion, how do I do it?
I am assuming that the g-code generated by fusion needs to have it's 0,0,0 to be the same 0,0,0 as my CNC machine, or a least that sounds the most logical way to do things to avoid confusion.
I am new to CNC btw.
daniel_lyall
No you don't set that in cam only on the machine all the cam needs to know is where the work zero is.
Have a read of this http://linuxcnc.org/docs/2.7/html/gcode/coordinates.html
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Thank you
daniel_lyall
Any time.
Just don't ask a question like that on the Linuxcnc forum you wont like the reply. on here any question is fine
Daniel Lyall
The Big Boss
Mach3 User
Is that because the question is to general? What kind of questions should I ask on Linux CNC forums?
daniel_lyall
A question like yours on the linuxcnc forum you would get told to RTFM  read the ducken manual.
They are quite blunt on that forum with question that reading the manual would answer, It's the reasion I stopped useing Linuxcnc A yes no question I would have some very nasty reply's
Daniel Lyall
The Big Boss
Mach3 User
