Fusion Manufacture
divot conundrum
4 REPLIES 4
ToolFool360
160 Views, 4 Replies
divot conundrum
Howdy, hope all is well. I am trying to figure out what I'm missing to make a toolpath to create these small divots in a kitchen knife. If you find the first sweep you will see I tried a weird cham profile. figured that was impossible to do seeing as how the smallest cham mill I have is 1/8. moved into a more "standard" profile where I revolved the tool diameter over an axis to create these divots. my initial thoughts were a spiral tool path but received empty toolpaths. fooled around with a few other paths to no avail. Seems like a fun little brain twister for all you advanced folks on here.
part link
https://a360.co/43eraZ9
4 REPLIES 4
a.laasW8M6T
in reply to: ToolFool360
Hi
I sketched a circle segment to Drive a trace toolpath for the first instance and used a 1/8" ball nose
Then Put the toolpath into a duplication Pattern, and used a projected sketch to define the source and target points.
Looks like it should work pretty well
See attached file
a.laasW8M6T
Actually, Here's a better one that uses the Project toolpath, this one is better as it doesn't overcut the part like trace does.
ToolFool360
in reply to: a.laasW8M6T
Whoa, I thought the project tool path was just for text... How long have you been using Fusion? You excel at this stuff, that would've taken me a few days to figure out if it wasn't for you. If you have a second to just look, would you have created a different tool path for the main profile of the edge bevel? or just stick with the 3d adaptive. Thank you for the solution!
a.laasW8M6T
Hi
I have been using Fusion for 5-6 years
See video for some more toolpath suggestions
I have attached the file too
